[SOLVED] Slideshow does not load images in Worpdress theme
Hello, I have installed Slideshow Gallery on my wordpress website at: http://villasavana.com/web
The plugin works great when placed on a page but I can only get the spinning wheel when I place the theme code into a theme template.
You can see this here: http://villasavana.com/web/?page_id=316
The upper spinning wheel is from the theme template and the lower image is from placing the link on the page. In the theme code, I have tried both:
<?php if (function_exists('slideshow')) { slideshow($output = true, $gallery_id = "1", $post_id = false, $params = array()); } ?>
and:
<?php echo do_shortcode('[slideshow gallery_id="1"]'); ?>
Both bring up the spinning wheel. If I change the gallery_id to a value that I know is incorrect, then the slideshow does not load at all, so I think that maybe it can't find the images. My wordpress sight is installed in a subfolder, so I modifed the helpers/html.php file to work with subfolders per a post I found at:
but this didn't make an difference.
I m using worpdress version 3.3.2.
Thanks,
Ben
This discussion has been closed.
