[Solved] Slideshow Borders Problem
We just updated to the latest version of WP and the slideshow plugin. Now, The right side of the slideshow is overlapping the page boundries.
You can see it on our soon to be homepage here: http://apld.info/apldtestingsite2/
Is this due to the update? Or do you see an issue with our page?
Thanks for the help!
@TweedleedeeTwit
You can set the widht of the slideshow in configuration settings. Can you please change the widht of your slideshow and see if it solves your issue? Slideshow>Configuration
@TweedleedeeTwit
I hope you are doing well.
I checked your site to see if the problem is resolved and it seems like the slideshow now fits perfectly and responds well to different devices as well.
I'll mark this as [Solved]
Feel free to post back if you need further assistance with this.
