thumbnails to appear vertically on left or right side
I just came across this plugin, and I must say great job!. Although my requirement is that the thumbnails appear on the right side instead on top or bottom.
Can you give me some pointers to where to start with for this customization.
Also the thumbnail section should also have separate specification for number of thumbnails to be shown at one time, right now it shows as many as it can fit below the big image. I need to use the extra space for something else.
I'm just following up to find out whether you managed to resolve your issue following our advice?
If so, kindly reply here and mark the thread as solved.
