order slides only by id
hi ![]()
I need to order slides only by id without manage order on admin's panel (it doesn't allow me this)
Could I force photos organization via php code?
hi ![]()
Thanks for contacting us and huge apologies for the very late reply!
Slides are by default ordered according to created date (descending), and if the IDs follow that same pattern the ordering should be fine (provided you add the slides in the correct order from the beginning).
There is currently no other way to change the order of the slides other than in the plugin settings. Any external manipulation of the slides ordering will have to be done by custom coding.
We recommend some freelance sites where you can hire developers/designers online at an affordable rate to assist you with your project: http://bit.ly/RCx12x
I hope this helps, donnafefe? I look forward to your reply.
Kind regards, Phil
