Change code generated by a snippet
Hello Tribulant,
We have been using wp-mailinglist for quite a while but now face a problem in the snippet functions. As stated in the topic http://tribulant.com/app/webroot/forums/discussion/51/solved-multiple-posts-insert-templates-and-styling/p1, it should be possible to change the file posts.php inside of the /views/default/ folder to modify the code that it put out when a snippet is inserted. However, nothing changes in the previews, even if we include some rules with TEST inside the file.
We have created an own template which we have set default. The reason why we want to change this, is that the links that are set in the mailing should point to an anchor on the main blog page instead of the blog permalink itself. Domain name is www.hunting.be.
Thanks for you advice,
We use version Nieuwsbrieven 3.9.9 in combination with WP 3.6
Kristof
