[SOLVED] Can't read 'Manage Subscriptions' text due to font color conflict with my theme
Hi - Is there any way to change the color of the text located inside the 'Manage Subscriptions' window?
(see below)... seems to conflict with my color scheme
thanks
CURRENT SUBSCRIPTIONS
Below are your current subscriptions to our list(s).
An Active status indicates that you will receive emails on that list.
It should be possible to resolve this with CSS, possibly without having to edit any files by entering the relevant code in "Use Custom CSS" under Newsletters > Configuration > General > Themes, Scripts & Custom CSS.
You could check your page's source code to find the relevant DIV or class element(s) for which to add a 'color' attribute.
Please let us know if that helped, will you Michael? I look forward to your reply.
For interest sake, would you mind sharing which plugin you're using for the conditional theme change?
Hope to hear from you soon!
