Could you just check again to see whether you're using the correct method to order the slides?
If you use the simple shortcode [slideshow], then slides should be ordered under Slideshow > Manage Slides
If you use the shortcode [slideshow gallery_id="x"], then slides should be ordered under Slideshow > Manage Galleries by clicking on the "Order Slides" link for a gallery: http://screencast.com/t/eTrRRY5442W7
I hope this helps? Please let us know, I look forward to your reply
Ordering the slides by the drag/drop method doesn't need a button - the order is automatically saved after every slide has been dragged/dropped.
Could you perhaps submit a support ticket at http://tribulant.com/support/ with your WordPress login details so we could investigate the blank slides issue and also why you can't order your slides?
Please also link us to this forum post in the support ticket.
And if "Get" = "Great" - then thanks for the kind words! :-)
