[Solved] Resize images not working
I have selected this option on the 'configuration' page, and it gives me a link to test if timThumb works, with a small thumbnail below it. When I click it, it shows the same image in a new tab. I don;t know what this means?
What I want is for it to reduce the images so both the height and the width fit into the available space.
Examle page: http://paulbruins.co.za/?page_id=346
Additional info:
Wordpress 3.5
Slideshow gallery 1.2.3.2, added via Wordpress plugins section (prev version of Wordpress, I think it was 3.1)
Thanks for your support request.
That link shows whether TimThumb is installed and working properly on your server. TimThumb is required in order to adjust the thumbnail dimensions via your plugin's configuration settings. The fact that you get the popup with the small image shows that all is well.
You can use the "Thumbnail Dimensions" setting under Slideshow > Configuration > General Settings to adjust the width/height of the thumbnails.
I hope this helps somewhat, Peter?
Sorry for the late reply.
Could you please give us a link to the page where the slideshow appears so we could investigate please?
