Any dates for WPML integration?
Hi
Like many others I've switched from qTranslate to WPML due to the lack of qTranslate maintenance for quite while now. I've seen somewhere around here that WPML integration is on the roadmap, is there any release date, as of when the integration will be done?
For the time being I'd be quite happy if I could translate the "subscribe" button in the widget...
Thanks,
Robin
Thanks,
Robin
Unfortunately we're unable to provide an ETA for the completion of the WPML integration, other than saying that we are working on it.
Will you be having a multilingual site? I'm sure it should be possible to search for the widget's search button's text string and translate it in WPML? Could you try and see if it works?
