Media directory and upload path settings
Hi there, I had some trials with the gallery plugin in a multi site install 3.9
Somehow it was not working well and I used the step 3 of image tester: try different path,
but I am not able to define all of my steps... finally I am in the situation that my image library is not working and my upload setting seems to be wrong.
however when I upload a new slide/image it will go to:
wp-content/blogs.dir/2/files/slideshow-gallery
and it could not be seen by the slide manager of the plugin.
(as I set manually to wp-content/uploads/slideshow-gallery)
I am looking for:
how should I set back the directory of the Media lib to see my earlier uploads?
how should I set back my standard (3.9) uploads directory instead of blogs.dir?
(as I know blogs.dir was used multi
.5 why it is appeared now?)
1. My earlier uploads to
wp-content/uploads/sites/2/2014/01
could not be seen in Media Library and it could not be edited
(no thumbnails only text and broken ikon)
2. If I upload a new picture it is going to
wp-content/blogs.dir/2/files/2014/04
and could not be seen in Media Library (text as above)
but could be open for edit.
I am looking for:
thank you for your kind help
Perhaps the change he states for development will help with your problem too? It would mean, however, you'll need to wait until the update appears.....
