I've just started to use the related products option, displaying underneath in grid format.However the products are not displaying properly in IE. Do I need to add some css workaround?
Hmmm yes I see it happening in chrome now, whereas earlier today it was ok. I'll submit a ticket.
Yes they are set to appear in grid format.
On a related issue, one of the options for related products is to have them appear in a 'tab' rather than below the item. Is there documentation on how to get this to work?
Thanks for submitting a support ticket, we'll attend to it a.s.a.p.
As for the related products in a tab, this documentation on the Product Page Settings shows you where that is set (about 1/3 of the way down, image no. 3 of 5):
Could you please provide us with a link to your site so we could check to see what would be necessary?
It's not only in IE you have the issue - this screenshot comes from Firefox.
Are you sure the related products are set to appear in grid format?
If you are unable to resolve this, could you please submit a support ticket, adding a link in your ticket to this forum post?
http://docs.tribulant.com/wordpress-shopping-cart-plugin/1484
I'm guessing you may already know that though... Here is other documentation about the Related Products feature that might help:
http://docs.tribulant.com/wordpress-shopping-cart-plugin/2036
Please let us know if this helps and whether you need more info?
