Hi! I would like to change the sidebar widget style to fit my theme. Which files should I edit and should I place the changed parts into the theme's child theme stylesheet? Thank you
You can change the widget style in your plugins stylesheet, and yes, you can add it to your child theme stylesheet to prevent it from being overwrite with a new update.
I have the Newsletter plugin and would like to change the sidebar widget that shows the signup form. Which classes should I add to the theme's child theme stylesheet?
You can edit "wp-mailinglist/views/default/widget.php" and "wp-mailinglist/views/default/css/style.css" according to your needs. The widget.php file contains the actual HTML and the style.css file the CSS.
