[Solved] Ordering slides within a post
Hi
I'm using the code [tribulant_slideshow post_id=xx] and uploading the media from within the post. Can you give me some specific details for how to order the slides, as I can't seem to change the order.
Is it to do with how they are named? Should they be alphabetical in terms of how I want them ordered?
Or is it something else? I've tried uploading them in a specific order but that doesn't seem to have an effect either.
I'd be grateful for some pointers.
Tonya
Tonya
