vertical slideshow
Hi
I have been trying to make a slideshow gallery with vertical and horrizontal pictures but my vertrical pictures are never fully shown.(even when I test this with only vertical pictures it still is faulty)
So I have made the gallery fixed (450x600) and scaled all my images in photoshop to fit perfectly (height 450, width 600) and no matter what, when I put my slideshow together they never fit propperly, the height is never correct, the sllideshow will allways zoom in as if the vertical image is to big when indeed it´s not.
Mind you the horizontal image never has a problem, no matter the size it will stay in there in full size.
I have been through the forum but none of the posts have resolved the issue.
can you please help me!!
Hi!
I'm having the same problem. Please see http://uniquelyannz.com/2015/05/18/elvis-vintage-wedding/
Horizontal images are fine but vertical images take up the entire width of the slideshow, even though I resized the images before uploading.
The slideshow would only work when I selected the responsive format so I cannot specify height.
I think this is a great plugin and very easy to use (I'm not very technical). Any help would be appreciated.
