[Solved] Any way to turn off redirect on double sign-up?
I have a very simple box (just email) so if they happen to put their email in twice, currently it tells them they did and then sends them to a management page. It would be better in this particular case to just not tell them anything or send them anywhere. Any way to do that?
You could try this under Newsletters > Configuration > Subscribers > Subscription Behavior:
http://screencast.com/t/sOJw7cBT6 or http://screencast.com/t/pODS2opl
Please let us know if this helped, will you?
My apologies, it seems the Management Page is a default setting if "Do nothing" is selected. Basically, it should do something - it can't just sit there leaving the subscriber guessing.
You could conceivably create a nice page telling the subscriber that he's already subscribed with that email address, but how happy and impressed you are to see that he's eager to subscribe again! Offer him a choice of handy links on your site or something to that effect - something like a well-designed error page.
Then you would obviously enter the URL of that page as the Custom Redirect URL with this option: http://screencast.com/t/pODS2opl
Do you think that could work for you Dave?
