cannot add a product to a cart
I have a product that I've been testing. I have tested it with 3 variations with success. I have tested it with 20 fields with varying amounts of options with success. But when I combine 3 variations with 15 fields, Checkout will not add the product to my cart. I started cutting down on the number of fields (11 w/3 variations) and it started working again.
Is there some sort of dim size limitation to the arrays that store the variation and field options? Or is there a limitation to something in the shopping cart?
Is there a solution for this problem?
I was using a combination of variations and fields.
One of the fields was named DOB (date of birth). No matter what data I entered into the text field, the product would not add to the cart. I have used this field name in the past with no problems. Since the last successful time of using DOB, I have updated WP, Shopping Cart, and Adv Coupons.
Could this be a corrupt data field of is DOB a reserved name or could it be something else?
