Product Description text currently not "responsive."
I'm having a bit of trouble with the Shopping Cart plugin. The Product description text is not resizing responsively on mobile devices. Any idea what I'm doing wrong?
http://interlockssalon.com/giftcards/
@jameswaldron
Thank you for your post and for reporting this issue.
The product description holder is actually set to a pixel width under Checkout > Configuration > Products & Images > Product Page Settings in the Shopping Cart plugin so that's the cause of this bug.
I'm adding it to our development list so that we can add a media query to override this at the correct device widths and make it responsive. I'm adding your discussion to the task so that I can post back here once it is fixed.
Thanks again and feel free to post back if there is anything else in the meanwhile.
@jameswaldron
Have you tried the new Bootstrap based theme folder included with our Shopping Cart plugin? It has a new layout which is fully responsive (including the product description).
That will solve the problem if you turn it on.
