Problem scheduling PlatinumPop popups
edited January 2013 in General
I can't schedule my PlatinumPopup popups for a certain date because the time is set to UTC.  My Wordpress settings are set to Pacific Time and everything else runs from this. Is there any way to change time settings so I can schedule popups for the correct date. With UTC as the default, a post that shouldn't show up until 12:01 p.m. on Thursday will instead post at 4 p.m. on Wednesday, as Pacific time is UTC -8.
  • 1 Comment sorted by
    Hi Hoodoo,
    There is unfortunately no such setting at the moment, but we'll definitely take your comments into consideration.
    We are in the process of transferring PaltinumPopup over to Tribulant Software, and this will go onto our development list of things to give attention to.
    Would you perhaps be able to compensate in the meantime? I know it's not the ideal thing to do, but it's the only way you would be able to do it at the moment.
