(Solved) Slideshow not loading , the circle is spinning
Hi ,
I am having a problem since a week , the slideshow on my clients site is not working , it was working a week before , but i dont know what happened and it has stopped working ,
i have already tried installing and uninstalling it severel times , also tried deleting the Images folder for the slideshow plugin , still no luck.
the site i am talking here is
rhetv.com
i have inserted the php code under the header to load the plugin .
using latest wordpress version .
Update :
The problem was solved from the theme developer.
problem was with the older jquery version of the theme itself , i replaced it with 1.7.2 version of jquery .
check your wp_register_script in funcitons.php of your theme for the version , it must be 1.7.2 .
