Problem with Thumbnails
Hey guys,
Lately I've been having a problem with my slideshows thumbnails. They are not being displayed, just the first image (it seems like there are not any other, but they are) and the only one that is being displayed, it does with incorrect dimensions (like cropped or something) and I've tried changing dimensions but it isn't working. I would be very grateful if you could help me.
Here is the example of what I'm saying:
http://www.studentsroomsbarcelona.com/gotico/
http://students-cp527.wordpresstemporal.com/rooms/room-1-gran-de-gracia/
King Regads,
Nana
Hello Nana,
Thank you for getting in touch with us.
Will you please open a new ticket under our helpdesk: http://www.tribulant.com/support along with your website WordPress login details so our team can take a closer look into this issue for you?
We`ll look forward to your response in order to better assist you.
Hello!
I'm facing the very same issue: http://ravina.com.ar/?p=131
There are several thumbnails, but it displays only one, and over-dimensioned. It seems to be loading thumbnails from the gallery folder instead of the thumbnails folder, so it ends up using as thumbnails the real pics
In my case, I developed the site in a domain of my own and then I migrated wp-content + database to production domain. I'm having this issue in production. Any idea?
Thanks in advance
After further investigation we were able to reproduce the mentioned issue, please make sure the following settings under the plugin "Slideshow > Configuration" section are properly filled with proper dimensions for your thumbnails: http://screencast.com/t/XAFPDSUFL7f
Let us know if it helps ok?
Hello Vitor, Thanks for answering!
Well, my problem is solved. As you mentioned I checked thumbnails dimension property and it was set 60x60. What I did was to "reset" the values. I set those to null, then to zero (just in case null values are ignored), then again to 60x60. After this, thumbnails are back in their size.
Thank you very much for the quick response and the fix, really appreciated! keep up the good work! congrats!
Hello McCoy,
I`m glad to hear that it worked! Please feel free to get in touch if you need further assistance.
Hi again, not happy I'm back =(, but I'm still having this issue. It came out of nowhere. Also, another thing I noticed is that in the slideshow list, menu "Manage Slides", pictures are really big, like in their original size, look: http://prntscr.com/7zqlof. This other issue was also there before, it's just I didn't mention it, and I don't know if the last workaround fixed it out.
Another detail, when I check through element inspector, I can see the images are taken from the gallery folder instead from the thumbnails'
Sorry the hassle, and thanks again!
any updates on this?
