[SOLVED] Category Grid Layout problem
edited February 2013 in Shopping Cart plugin
I'm having an issue with my category thumbnails not aligning in a grid format. I have a category in which there are several sub categories. When the category link is selected then the sub categories are shown, with thumnbails, and are set to display in a grid format. But, they are showing in a list format. I'm playin about with the css but having no luck . Has anybody had similar issues or any tips on how to get this to display correctly? I presume its a conflict with my theme thats causing the issue
Edit: Ah it's ok, I had the shopping cart css code pasted into my themes code, so I had to set the categories ul li to display as inline-block
