Remove "Options" From Cart?
edited January 2013 in Shopping Cart plugin
I'm selling products that don't have any "variations/options". Is there an easy way to "remove" that column from showing in the cart?
Thanks,
Jay
  • 1 Comment sorted by
    Hi Jay,
    So sorry for the late reply!
    There is unfortunately no way to conveniently remove the column from inside the plugin's configuration, so it would have to be done "surgically" by editing the file wp-checkout/views/* your theme folder */cart.php.
    If you feel this might be too daunting an undertaking, you're welcome to submit a support ticket at http://tribulant.com/support/ with WordPress admin login and FTP access details, and we'll remove the column for you.
