Page load time
I have been running the P3 profiler to take a look at the effect of plugins on page load time. Currently the newsletter plugin is responsible for approximately 0.8s of this which does seem a bit excessive. Is this what you would expect or are there a few things I can do to try and shave some time of this?
@creativitymatters
Thank you for your post and for your feedback on performance.
Is the 0.8s added to the page load time consistent or does it go up/down?
If it is not consistent, it could happen as crons from the plugin are running.
Are you using the standard WordPress cron for your WordPress installation?
Or have you tried DISABLE_WP_CRON as well as replacing it with a server cron?
Please see this as it may help increase performance: http://tribulant.com/blog/wordpress-2/replace-wordpress-cron-with-real-cron-for-site-speed/
I have disabled Wordpress cron and am using server cron to run the wordpress cron php file as per one of your blog articles. I was doing this as part of trying to fix autoresponder and email scheduling! Neither has worked yet.
The 0.8s load time is fairl consistent. It might go down t 0.7s or so but it never goes away. Max from any other plugin is 0.3s.
@creativitymatters
May I have a link to your site to check?
If you can't provide it here, can you submit a ticket, please: http://tribulant.com/support/
Site can be found at www.derekcheshire.com
@creativitymatters
I see that you're already using the
default2theme folder in the Newsletter plugin which is good.Apart from that, we would like to run a test, deactivate the plugin and run another test.
That way we can compare and see what is causing the load.
Can you please submit a ticket so that we can check that? http://tribulant.com/support/
I have been away for a few days so will sort this as soon as possible
@creativitymatters
Did you create a ticket for this yet?
There have been some improvements to performance in version 4.5.5.4 of the Newsletter plugin. Can you check if that has made any significant improvement?
