Problems updating to latest version
Tried updating this morning and after updating the plugin I find that it has in fact disappeared? It seems to have removed the old one and not installed the new. Is this an issue or have I inadvertently caused this to happen.
Returning to old version via backup for now.
@creatibitymatters
We are really sorry about the inconvenience caused, we found a problem in v4.5.5.4
They latests update will solve your issue or alternatively you can install the following build on your website: https://drive.google.com/file/d/0BxEXbXgpOdIjd0lBZjBUWHVzZzQ/view?usp=sharing
If you want we can go through your website and install it for you, we just need your website URL and WordPress login details in order to do so.
Please let us know if it helps ok?
@creativitymatters
We released version 4.5.5.4.2 of the Newsletter plugin today to resolve the update issues.
If you have to, please update manually and rename your plugin folder manually to
wp-mailinglistThe update will also fix the issues that you had with the autoresponders before.
Enjoy the fixes and improvements made, we hope it helps.
