mobile responsive layout
I have both landscape and portrait images in a gallery for a slideshow I created. I have activated the responsive layout which seems to rotate the images when I view my page on a computer. When I view it on my phone the portrait images do not rotate and adjust instead they show up sideways in landscape. Some help would be great! Thanks!
website: http://drunkonshoes.com/2015/09/nyfw-day-one-marissa-webb-vest/
@DrunkOnShoes
I checked your link but it shows a database error at the moment so I cannot see. Can you please check and make it active?
The images do not rotate on the responsive layout, they simply resize with the slideshow as the slideshow resizes with the site, that's all it does.
the link is working for me.
can you try again? i guess i'm not sure then why on my computer the images slide fine as in landscape images show landscape and portrait shows portrait.
but when viewed on my phone, the images all show as landscape so the portrait images are rotated 90 degrees.
@DrunkOnShoes
Thanks, the link works now. It may have been a temporary issue.
That's very odd, the plugin won't rotate any images. It doesn't happen on this side either.
It might be something in your theme or even on your phone?
Can you try a different phone?
