Hi, I did see an older post about the same problem: guest checkout isn't working and it's requiring people to register to pay. I checked the downloads page and I see the latest version is 1.1. We've got 1.0. Would that be the cause? Thanks!
Hi Marietha, I do have the correct settings. It's worked great for years until now. Is there anything special about installing the latest version? Anything I need to be careful about? Or do I just upload it to the plugins folder.
@milauskas
Can you download the latest version and install it on your site?
You will find settings for guest checkout under Checkout>Extensions - Settings.
http://www.screencast.com/t/pztWL8QGRI
Please make sure that you've select the correct settings.
@milauskas
No, nothing special. You can just replace it with the new version. The new version will solve your issue.
@milauskas
Did you manage to upgrade your Guest Checkout extension plugin for the Shopping Cart plugin?
