[Solved] Slideshow broke with no apparent reason
The site was up and running for more than a year and before some days I saw that the galleries doesnt show as they were supposed to. The images are showing but hte gallery "operation " is broken. I proceed with fully updteing wp and slideshow plugin with Check/optimize database tables, and reseting to default but the issue remains. I have also disabled all plugins and verified that none is interfering.
prior to this, I had moved my site to a different server and I think that I checked the slideshows and were operational.
The website is here
@xalaros
I notice some errors, where the slideshow can't load the styles. http://www.screencast.com/t/l4rW8FJZwMCD
Failed to load resource: the server responded with a status of 403 (Forbidden)
Is it possible to ask your hosting provider why it's forbidden to load these styles? Do you have security enable?
@xalaros
I hope you are doing well.
I checked your site to see if the problem was resolved and noticed that the Slideshow Gallery plugin is indeed running and functioning correctly as it should be.
I'll mark this as [Solved].
