[Solved] Adapted Pro-news template not sending or previewing
I've started a new thread because I narrowed the issue to the template.
My problem seems specifically to do with the plugin template I adapted from the Pro News template. I was able to send it before but maybe something I altered is causing the problem. Can anyone please help me identify this problem with the html? It will send with no template or any other template so it must be something to do with my adapted one? Thank you!
See the adapted http://alivewithoutamanual.com/wp-content/uploads/alive-template.html
Yes it was something in my code! Figured it out!
@barb
Great, I'm glad to hear that you solved this.
I'll mark this as [Solved].
