How we can send an autoresponder only for specific custom field, like gender.
Tks,
@Med
You can try to set the segment on a newsletter and then select the newsletter when sending the autoresponder.
How can I set the segment on a newsletter witout sending the newsletter, if I want to just use it with autoresponder.
Med
I've been testing and the autoresponders are not working with condition fields at this moment.
I've add it as a task on our dev list for you.
set the segment on a newsletter and then select the newsletter when sending the autoresponder, is this working ?
No, it's not working. I've been testing it.
Have you test it and is it working for you?
No, it's not working, autoresponder is for all subscribers
Yes, it's a task on our dev list to make the segmentation on autorepsonders possible.
Can you give us somme help to do that, it's urgent.
Just show us where we have to change the code.
It looks like you're new here. If you want to get involved, click one of these buttons!
Please wrap your code in <pre lang="php">code here...</pre> or <code>code here...</code> tags
Please edit your topic and add [Solved] to the start of your title when your question has been answered
@Med
Med
@Med
@Med
Med
@Med
Med
