At this time the "Save a Product" page, used to create/edit a product, only has a normal browse computer & upload function to add a product image to a product.
You can, however, add the same product image to two or more products by using the "Import Products" function to add products to your store, instead of creating them under Checkout > Products."
http://docs.tribulant.com/wordpress-shopping-cart-plugin/1892
