Cannot chose a post
when i want to insert a post, i can't chose a post, even if i chose a category above.
https://d.pr/11LjG
https://d.pr/11LjG
Thank you for your message. It's currently not a known issue in the plugin.
Which version of the plugin are you using?
Is it possible to open a support ticket with a link to your site and WordPress login details for us to have a look at your issue? http://tribulant.com/support/
I suspect there is a Javascript error causing the posts not to load.
Are you able to check your browser's console for a Javascript error after you've chosen a category?
If you don't know the console, please submit a ticket to us: http://tribulant.com/support/
