[SOLVED] Lightbox is thin line in IE8 only
Hey Guys, I've really enjoyed using your product so far and I'm hoping we can fix this bug.
I'm using Version 1.2.2.1 of Slideshow Gallery and the site is using Wordpress 3.4.2: http://www.edmanson.com.au/photos/
I've tested this in chrome, safari, IE7, IE9 and firefox and it all works fine, as far as I can tell this is only happening in IE8.
In IE8 when you click on an image in the slide show, the lightbox opens up as normal but when it finishes loading the image it appears as a thin white line.
I suspected it may be a caching/minify issue so I've disabled the W3 Cache but that didn't make any differences.
Thanks in advance,
Dave.
For anyone else who has this issue you need to go to:
../wp-content/plugins/slideshow-gallery/css/colorbox.css
Thanks again for your help and FYI the JavaScript looked just fine as it was. However I did replace them with the newer version and it didn't seem to cause any problems.
