[SOLVED] Using Really Simple CAPTCHA in subscribe shortcode
I have the newsletter subscription in a widget which is using Really Simple CAPTCHA in it. How do I also have the captcha field in the shortcode embedded option? I have a subscribe page with the form added via shortcode.
Under Newsletters > Configuration > General > Default Subscription Form Settings there's an option called "Use Captcha for form." Set that to yes, and it will use the Captcha for every subscription form.
http://screencast.com/t/AfLV0Fdg0b5
I hope that helps?
Thanks, that helps.
