PlatinumPopup Mobile Settings
Does this plugin offer mobile settings?
For example, do you have:
a. A choice not to show the Popup in mobile (smartphone) environments.
b. A choice to resize for mobile smartphones.
Currently, this plugin does not work properly in mobile -- given it takes up the entire screen and you cannot close it easily given it is outside of the display area.
I'd rather not make the popup window small (mobile resolution) as this looks odd for larger screen viewers. Please confirm a workaround for this.
Thanks.
Thanks.
I'm afraid PlatinumPopup was never designed with mobile browsers in mind (short-sighted, I do admit), but it is on our development list to implement mobile compatibility as soon as possible.
I hope this helps? Please feel free to give us a shout if you need any further support.
[EDIT] I have to just mention that the plugin was developed before it was moved to Tribulant Software. we are now working at setting right the pre-existing design flaws.
