[SOLVED] Newsletter brakes another plugin... lots of problems
Hello!
I am using wordpress 3.4.2 and Newsletter 3.8.4 on responsive theme with thematic.
I am using plugin "SSP Director Tools", this plugin uses "FancyBox" to present images on blogs, widgets and pages. The problem is when I activate Newsletter the FancyBox stops working and I get an image in a blank webpage instead of transistion and overlay. It brakes this function for the SSP Director. I then tried to update to your latest version of Newsletter 3.9.4 to see if that would help! But when updating to your new version broke my website. I was not able to log in or open any page at all so I had to go use a backup to recover. I did try two times with the new version and I got the same result = website broken. What I did was to copy the folder into the plugin folder and overwrite the files in Newsletter 3.8.4. Is this the correct way to do it? Should I remove the older version first (no risk to loose the data?). I need advices here to get FancyBox working with SSP Director Tools and have then Newsletter working as well. Website is www.digitalworkflow.se. I have deactivated the Newsletter as I need to have the FancyBox working!
I will activate newsletter plugin in about 3 hours as I'm on travel at the moment.
I did deactivate the plugin before copy the new version but after activating the new version the website goes down, tried two times with the same result
