Conflict with calendar plugin
I recently installed the Events Calendar Pro plugin (from Modern Tribe). One problem I was having was that events that fall on the last day of the month will then repeat every day of the following month.
Modern Tribe support had me deactivate/reactivate plugins to find a conflict and it looks like it's the Shopping Cart plugin that is causing this daily event repetition. If I deactivate the shopping cart, the problem disappears. Can you shed any light on this or maybe point me in the right direction to try to fix this? Thanks!
We had a similar issue with an event calendar plugin not too long ago. I'm not sure if it was the same one. It turned out the issue was not with the Shopping Cart plugin, but with the calendar plugin.
The plugin subsequently released an update with improved queries and it resolved the issue.
Would you mind asking Modern Tribe to debug your calendar's output and see whether it might not be their plugin's fault? We're not trying to shift the blame, it's just that we know from the previous case that our plugin wasn't to blame.
Thanks for letting us know, much appreciated.
Is that the time zone setting in WordPress or in the Event Calendar plugin?
