No Lightbox when showing thumbnails ?
Hi
What a great plugin guys !
However i have a small issue... When i'm turning on thumbnails - lightbox seems to stop working and i can't to click on image to see enlarged picture (also small next/previous arrows isn't working).
Also when i switch to another slide manually (using main next/previous buttons) slideshow stops... Is there anyway of having autoslide ON all the time?
I'm using wordpress 3.5.1 and slideshow gallery 1.2.3.2
Thanks in advance....
Maciej
Thanks for you support request and for the kind words
Would you mind giving us a link to check on the lightbox issue on your site please? That sounds rather odd.
As for the autoslide that stops when the navigation is used - that's how it works currently, I'm afraid. We have it on our development list to add a setting in the plugin configuration that will make that optional.
I hope this helps? I look forward to your reply.
