Problem with accents in French
Hi everybody
I use Newsletter plugin in a French website, therefore with accents (é, à...)
Some recipients of my newsletters see accents with encoding problems, typically:
instead of:
How can I fix this problem? Do I have to insert the htmlentities() function somewhere in the code of the Newsletter plugin?
Thx in advance for your help.
Les assemblées générales régionalesinstead of:
Les assemblées générales régionalesHow can I fix this problem? Do I have to insert the htmlentities() function somewhere in the code of the Newsletter plugin?
Thanks for your post and for reporting the problem.
We are currently testing the accents here on our side and will confirm if there is a problem which we can duplicate and then we will suggest a solution to you.
I'll post back here shortly.
perhaps could you try to modify the newsletter template to add the charset according to your encoding...
In the header, try to add or modify charset declaration like in the followed examples :
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
or
<meta charset="UTF-8">
