[Solved] Losing WP admin when plugin activated
I just upgraded a couple of sites which had not been updated in a few years, I think. But if the plugin is activated then I lose the entire admin panel. If I then go and rename the plugin, I get the admin panel back but am unable to use the plugin. Is there a conversion of old data that needs to be done?
It is most likely a PHP fatal error which shows a blank/white page.
To see what the error is, please turn on debugging in your wp-config.php file by setting the WP_DEBUG constant to true.
If the problem persists, please submit a ticket through to us.
We resolved this in our help desk with you.
There was a conflict with MonsterInsights but it is working fine now.
I'll mark this as [Solved]
