[SOLVED] Images not showing after server move - TimThumb error
I have my dev site and the temp site I am moving to both on BlueHost. The images are over at the new server, but the slideshow images and thumbnails are not appearing. When I click to open an individual thumbnail in the slide show I get this error below. Plus, this is the link in the slideshow, http://69.195.124.97/~johnfarh/wp-content/plugins/slideshow-gallery/vendors/timthumb.php?src=http://69.195.124.97/~johnfarh/wp-content/uploads/2013/05/IMG_0039.jpg&w=105&h=80&q=100&a=t
TimThumb version : 2.8.10
A TimThumb error has occured
The following error(s) occured:- Could not find the internal image you specified.
But when I go to the image it is there. When I look in the database the path seems correct, so I am not sure what the issue is and I would really like it addressed so the site can go live. Thank you so much.
I also called the hosting company and they said they were not doing anything to block the TimThumb.
The issue here is the tilde (~) character in your URL. If you can change that, it should solve your issue.
Please let us know if this helps, will you?
