[SOLVED] Gravity Forms Plugin Not Showing Settings In Plugin
edited September 2012 in Newsletter plugin
Antonie,
I just installed the Gravity Forms plugin extension for WP Newsletter, and it will not show the settings in either the wp-newsletter plugin, or the gravity forms plugin.  I am able to see the newsletter add on in gravity forms when building my form, and I am able to add it on the form, as you can see here: www.dumpthatdebt.com however, it will not show the settings for the form.  It also does not work.  When I add the subscriber on the public front end, it will not add the subscriber to the tribulant newsletter default list.
Any help you can provide is greatly appreciated.
Taylor
  • 2 Comments sorted by
    Thank you for your post, Taylor.
    So you can see the "Newsletters" field in Gravity Forms plugin under "Advanced Fields"?
    Please click on it to add the subscribe checkbox to the Gravity Forms plugin form.
    If you experience problems with it, please submit a ticket to us to check: http://tribulant.com/support/
    I believe that an outdated WordPress and outdated jQuery version caused the problem in Gravity Forms and that upgrading WordPress solved this problem.
    Let us know if you need any further assistance Taylor.
