[SOLVED] Custom field how to require a specific choice?
edited September 2012 in Newsletter plugin
I created a custom field with newsletter called (TOS) terms of service
The field type is 'radio buttons' with 2 options (yes, no).
I set the TOS field as required and gave it an error message if not completed.
What I can't figure out:
How do I make it so that the user has to choose (Yes) in order to submit the form?
It does me no good to have a TOS field set to required if the user can select NO, and still register.
Make sense?
Solution?
  • 3 Comments sorted by
    Best solution is to create a checkbox custom field.
    It will have one option/checkbox "Yes, I agree to your terms and conditions".
    If checked/ticked, the user agrees, if not, the error message will be shown.
    Please let me know if this helps you.
    Antonie
    That's fine, for now I will use a checkbox field.
    Would be nice to add in the conditional logic for checkboxes in the future though.
    Thank you for your response.
    I'm glad to hear that the checkbox works fine for you.
    We'll make a note of this conditional logic so that we can consider making it available in the future.
