[SOLVED] multiple posts insert, templates and styling
how can i make a template for multiple posts insert in a newsletter; i need to adjust thumbnails size, fonts...
thanks for help
thanks for help
thanks!
I've the same need, what do you need with *themefolder* ? In the "views" folded I ony see three folders:
admin
email
default
Thank you
Dimitri
The * themefolder* refers to "default."
Could you please describe a little more what it is that you need to achieve? And when you mention "template" do you perhaps refer to the newsletter theme (in other words, how the newsletter should look)?
