[SOLVED] How to get shop categories in menu?
Hi, I've just installed this plugin and I'm relatively new to WordPress. I'm using the latest version of both the plugin and WP.
I just want to show the top (parent) product categories in the main menu, which I guess is the default Pages menu (the WP menu settings interface is really confusing). I turned on permalinks so that categories can be accessed by xyz.com/product-category/category-name, but I don't know how to get the categories to show up in any menu. Do I have to manually create a new page for each category and use a shortcode?
Secondly, if I create a page and use a shortcode, the permalink gets a number appended to it, presumably because the name is already being used with the plugin's auto-generated URL. So using the example above, if I want "Category Name" to be a new top menu item, I create the page, insert the shortcode for that category, and the permalink becomes xyz.com/category-name2. But I don't want the "2" there, I just want a way to link the auto-generated URL (xyz.com/product-category/category-name) in the menu.
This discussion has been closed.
Continuing on this topic, I noticed in the demo under Appearance > Menus, there is a section called Shop Categories, among others. Why don't I see that in my installation? All I have is Pages, Links, etc.
