[SOLVED] Product image not appearing
Whenever I try to add an image for a product, it simply won't take. No error messages or problems, it just doesn't upload. Adding extra images is fine but I can't seem to add a main image for a product.
No strange characters in name, .jpg format and over 250 pixels in size.
Any ideas what I'm doing wrong?
  • 3 Comments sorted by
    Thank you for getting in contact with us.
    Can you please try to use a different image or re-save your current image in a different format such as jpg, png, etc?
    If the issue persists can you please make sure that the following folder is created: wp-content/uploads/wp-checkout/images?
    Let us know if it helps ok?
    After checking the folder structure, the images seem to be uploading fine as they're in the folder.
    I think the problem may have been that the product title was in Chinese. I found a work around where I keep the title in English when initially uploading and then simply change it afterward.
    Thank you for your help.
    Thank you for your response and for sharing your solution with us.
    That`s great to hear! Please feel free to contact us if you need further assistance.
This discussion has been closed.
