Email addresses sent wrong
I've following problem. When a user registers with the following address. For example.
name_surname@provider.com
The plugin sends automatically to : namesurname@provider.com so without '_'.
What can i do?
cheers
This is a known issue in a past version of the Newsletter plugin that had been fixed quite a while ago.
Your solution would be to update your plugin. You can download the plugin at http://tribulant.com/downloads/, and find the install/update documentation here: http://docs.tribulant.com/wordpress-mailing-list-plugin/31#tabs-3
If you need to renew your download subscription in order to update, you can use the coupon code "CHRISTMAS" (without quotation marks) for a 30% discount on your renewal.
Thanks for letting us know
