[Solved] Searching posts
I know there's a built-in search for the FAQs, but for a number of reasons it doesn't work for us. Having the system generate posts and using the site wide main search kind of works, but because the posts are created using short codes, the main search doesn't see them. Can you suggest a search plugin that might work well with the posts as your system creates them and simply extends the main search?
