403 Forbidden on edit slides
Please refer to this link for the issue that occurs:
https://wordpress.org/support/topic/403-forbidden-on-edit-slides?replies=2
Thanks for your help.
Matteo Andreatta
Matteo Andreatta
@tobeplus
403 Forbidden is a server side issue which usually refers or relates to security such as Apache mod_security or something similar. In most cases, it is Apache mod_security.
Which procedure are you using specifically when you add/edit a slide?
Do you upload an image or do you choose one from the media library or?
Also, what is the link/URL in the address bar at the time of the 403 Forbidden error?
I look forward to your response with more details.
any solution to this one yet?
Having the same problem when clicking save after editing a single slide inside a gallery.
WP4.2.2
Hi, i've have the same problem.
Wtih a multiple upload is all ok. With a single upload it doesn't work. So the slide is online, but i can't add the link.
The link at the time of the 403 is :
MYSITE/wp-admin/admin.php?page=slideshow-slides&method=save
Wtih an Add multiple upload is all ok. With a single upload or edit existing slice doesn't work.
please help.
Do you also get a 403 Forbidden error when you try to save a single slide? Or what happens specifically?
Can you please open a ticket here: https://tribulant.com/support/
