Retail/suggested price description is misleading
When you are setting up products, under the retail/suggested price it says: Actual Price after markdown or suggested manufacturer price
Except the actual price after markdown is what you would be putting into the Fixed Price box. It crosses out whatever number is in the retail/suggested price box. It should really say before markdown to avoid confusion.
Just a minor thing but it could easily be fixed with the next update
Also, is there any chance that we could put the crossed out number in red to really highlight the savings?
thanks!
Thanks for the suggestion - I'll pass it on. :-)
