Empty shopping cart redirects to homepage...
I had commented on a previously SOLVED issue, however the solution is not working for me.
I am having this same issue as the user in this post: http://tribulant.com/forums/discussion/1706/solved-continue-shopping-button-redirecting-to-homepage/p1 However, I have checked in the configuration and the URL on the config page is set to the shopping cart page, but when clicking on an empty shopping cart page it redirects to the homepage rather than the shop page.
Appreciate your assistance.
@acaweb
Please make sure that your shop url is set to the url of your shop. Something like yourdomain.co.za/shop
An empty cart will redirect to your shop url filled in under configuration settings. Please see my screenshot: http://www.screencast.com/t/O0sl8FSpc
@acaweb
I hope you are doing well.
Did you manage with this?
Did setting the "Shop URL" solve the problem?
